Coating unit Bounce
Discussion in 'Mitsubishi Printing Presses' started by Frankjmh, Oct 25, 2019.
  1. Frankjmh
    Frankjmh New Member
    Jul 2018
    Pennsylvania
    We are experiencing "bounce" on the tail end of our sheets coming off the coating unit. It is on the operator side and at the bottom of the sheet it is creating a miss in the varnish. It is also creating build up on the varnish plate in the same area and causing the sheets to stick towards the end of the run. We have replaced the cam follower and lever on the operator side, but has not made a difference. Looking for any suggestions
  2. turbotom1052
    turbotom1052 Senior Member
    Oct 2008
    1,062
    Vermont
    not fully understanding what you're asking... You mention a varnish plate, and in another breath you talk about a coater. Please verify so that we can help.
  3. NotAGooner
    NotAGooner Senior Member
    Dec 2007
    279
    UK
    Isn't what he is referring to, a Cyrel plate, it's a letterpress plate for coaters?
  4. turbotom1052
    Oct 2008
    1,062
    Vermont
    i suspect we will never know to what he is asking. I do know that in some parts of the world, coating applied through a printing unit is also referred to as "varnish".
  5. hold_my_beer
    hold_my_beer Member
    Feb 2019
    7
    OKLAHOMA
    Have you changed the felt pieces on the ends of the coating roller? Also, have you timed the coating to see if it's too thick or too thin? Are you using paper packing or that soft black 1 piece packing?
    On a lighter note, has this problem caused you to gain a new addiction?
