Does anyone know how to disable the functions of the LA8 dosing pump without causing system errors to display?
I'm wondering if it's possible to create a simple system that, once plugged in, can trick the system. A 24V solenoid valve, and then there are 2 sensors. I don't know what materials to buy to assemble in order to trick this system
Use a 24V Relay. Conect the coil of the relay on the place of the solenoid, use the NC contact on the place of the sensor that is located on the metal body.. the level sensor you just jumper it...
If possible, could you provide some actual item photos and create a simple schematic diagram? Thank you very much."
