Transport Sucker R700
Discussion in 'Man Roland Printing Presses' started by matthias76, Dec 10, 2019.
  1. matthias76
    matthias76 Member
    Nov 2016
    42
    Germany
  2. CHOCK
    2,895
    Adjust sensors+and Clean it very well, about 75 mms, as the schematic attached.
    Drive pile to working Height.
    Do it with the screw number 2 indicated in the schematic attached
    LED will be light up.
  3. matthias76
    matthias76 Member
    Nov 2016
    42
    Germany
    Thought there is less vacume air or mechanical problem.
    Nothing to clean in transport sucker ?
  4. mantman
    mantman Senior Member
    Nov 2015
    274
    Greece
    Perhaps there is a leak of vacuum, because of clogged paper dust or even the piston that drives the sucker down is worn. Try to clean sucker with compressed air before you disassemble. Also if rubber disc is used for long, flip side or change it.
  5. mendietta
    mendietta Senior Member
    Oct 2019
    112
    Slovenia
    Only one sucker?
  6. CHOCK
    2,895
    Clean hoses, filter, and tight any clamp in the hoses, or replace by some leakage, in the system
    And LUBE, properly according with the instruction manual coming with the machine.
  7. matthias76
    matthias76 Member
    Nov 2016
    42
    Germany
    Sucker out left and out right the most.
  8. mendietta
    Oct 2019
    112
    Slovenia
    Problem can be in suction head valve, usualy is dirty, it is on the right side of the feeder,little above head. I dont have my service manual now, so i dont know the wright name. But you can find it easy, hoses from suction head are conected to it... But be careful,i reccomend you to pull out hose first and check if there is enaugh vacum... it is not easy to assemble this valve...
  9. drukman
    drukman Senior Member
    Mar 2016
    283
    Bulgaria
    Old problem. Replace the original black vacuum hoses (tubes) to the valve. A side.
  10. CHOCK
    2,895
    Please proceed with that indication from
    our colleagues, and description that I did.
  11. TMI
    TMI Member
    Dec 2018
    10
    Tucson Arizona
    What is the durometer of the vacuum suckers?
