Polar Guillotine Green belt tension is lose
Discussion in 'Heidelberg Printing Presses' started by Slenzie, Apr 4, 2024.
  1. Slenzie
    Slenzie Member
    Apr 2024
    8
    Papua New Guinea
    Hi everyone,
    Green belt for Guillotine polar is lose..any ideas to tension it to make it tight..
  2. CHOCK
    2,892
    Has a Large Bolt with a nut under the table running in 2 rollers, front and rear, where is located the Bolt + nut for adjustment.
    Slenzie likes this.
  3. Slenzie
    Slenzie Member
    Apr 2024
    8
    Papua New Guinea
    Thanks sir, I will try locate the bolt + nut and get back to you.. thanks so much for your response I really appreciate it
  4. CHOCK
    2,892
    OK Sir.
    Good Luck.
  5. Slenzie
    Slenzie Member
    Apr 2024
    8
    Papua New Guinea
    Can you indicate the bolt from this picture, just to make sure I'll do the right thing
  6. CHOCK
    2,892
    I can Not see it, however am attaching Pic of adjust Bolt.
    Slenzie likes this.
  7. Slenzie
    Slenzie Member
    Apr 2024
    8
    Papua New Guinea
    Thank you sir, now I see it clearly. I'll try adjust it and get back to you.
  8. CHOCK
    2,892
    OK. Sir.
